3CX Phonesystem build v3563 Final?
Discussion in '3CX Phone System - General' started by AldoLinares, Dec 5, 2007.
  1. AldoLinares
    AldoLinares New Member
    Nov 12, 2007
    135
    It is the final version v3563, i am little confused because it's the same build as the RC2.
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    I think the prefect 3CX should be so far away from us. It should be have so must area to be improve. Even that, now it should be must more enough for small business to use. But in windows base, it should be the TOP one. The bug fixed version will be come soon. That mean there is never found the final version. All software's final version should be its company's closing day. :(
  3. Mori
    Mori New Member
    Mar 23, 2007
    223
    In short words.
    No, its not final. :)
    Build 3563 is the RC2, but is published for everyone to test.
    Stable v.5. is due right over christmas... i hope...
  4. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,991
    304
    3563 is the final, but in publishing the final version we have met 2 last minute bugs which we are addressing as we speak. So yes it is the final but not for very long :-( We are targeting a new upload tomorrow with the main issues fixed as follows:
    1. Can work in DMZ or on Public IP. Current version will not work on a public IP or in a DMZ
    2. Rejected calls will count against license limit and cause confusing error messages.
    Both and some other things are fixed in the build to be uploaded tomorrow.
