3CX PhoneSystem Installation Error
Discussion in '3CX Phone System - General' started by len@Arena, Apr 4, 2013.
  1. len@Arena
    Aug 4, 2009
    11
    I am trying to install the 3cx phonesystem v11 on a windows server 2008 R2 and I keep getting the following error:
    Product: 3CX PhoneSystem -- Error 1330. A file that is required cannot be installed because the cabinet file C:\Users\Administrator\AppData\Roaming\Install\MainFeature.cab has an invalid digital signature. This may indicate that the cabinet file is corrupt. Error 272 was returned by WinVerifyTrust.
    Has anyone encountered this? Ideas on solving it?
  2. len@Arena
    Aug 4, 2009
    11
    Just in case someone encounters the same problem, somehow the server where I was installing 3cx was not updating the root certificates.
    Had to install them manually from here: http://catalog.update.microsoft.com/v7/site/search.aspx?q=931125
