3cx PhoneSystem Nginx Server not starting
Discussion in '3CX Phone System - General' started by Serhiy, Jan 14, 2019.
  1. Serhiy
    Oct 25, 2017
    21
    I have issue with 3cx PhoneSystem Nginx Server, it`s not starting after reboot the server.
    Also service is not start after reboot with automatically up and when you try to load service manually. (screenshot attached in Russian Language)
    Screenshot translate -
    Can`t load 3cx PhoneSystem Nginx Server service on WIN-10RL1PU90EI.
    Error 1067: Process suddenly killed.
    In nginx error log in path - C:\Program Files\3CX Phone System\Bin\nginx\logs\error
    When I`m start service it`s added :
    2019/01/14 17:37:01 [emerg] 5932#4316: WSASocketW() failed (10044: The support for the specified socket type does not exist in this address family)
    Our license is Pro 15
    OS server is Windows Server 2008 R2 Standart.
    Please help us to resolve this issue.
    Thank you
  2. Marari
    Marari Member
    Sep 16, 2007
    283
    66
    @Serhiy
    Please indicate your full version (15.5 SP6? )
  3. Serhiy
    Oct 25, 2017
    21
    I` guess it`s 15_5 SP1
  4. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,773
    278
  5. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    564
    As mentioned try to upgrade your PBX to the latest stable version first and see if that resolves your issue. You may way want perform a backup before upgrading though. You can use the method outlined in the following guide. https://www.3cx.com/docs/backup-restore-command-line/
