3CX PhoneSystem Services
Discussion in '3CX Phone System - General' started by tobiastromm, Jan 20, 2011.
  1. tobiastromm
    tobiastromm New Member
    Jun 26, 2010
    138
    I have some problem with two services.
    I cant start Call History and Queue Manager services.
    Sometimes they start when I restart the server.
    Without this services the Log of calls don´t work.
  2. danielbo
    Apr 17, 2008
    20
    Is there a way to do hands free intercom. What is the page feature on the feature list (*9).
    Thanks for any suggestions,
    Dan
  3. tobiastromm
    Jun 26, 2010
    138
    Danielbo,
    I really don't understand what you say :oops:
    Bad, bad english.
    Can you use another words?
    Thank You.
  4. complex1
    complex1 Active Member
    Jan 25, 2010
    752
    38
    Hi tobiastromm,
    Have you try a complete uninstall of the 3CX Phone System, restart your computer and then install 3CX from scratch?
    Maybe this solves your problems?
  5. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    can you check your windows event log for 3cx entries and post the details for us to see?
  6. tobiastromm
    Jun 26, 2010
    138
    Hi.
    I find some entries in the Windows Event Viewer:
    Thank You.
  7. abc123
    Nov 9, 2009
    712
    Although my spanish is very poor it looks like you are timing out starting the service and no other logs.
    I would try to uninstall and then reinstall as it may have caused a problem.
    You could also try to go into the Services on your PC and manually start it to see if it starts then stops or doesnt start at all.
    Are you running v9 with sp5a?
  8. tobiastromm
    Jun 26, 2010
    138
    Yes,
    I`m running the last SP:
    When I try to start the service in Windows Services, the same error occour:
    Thank You.
  9. abc123
    Nov 9, 2009
    712
    So it didnt start in a timely manner, rather than start and then stop due to an error.
    In which case i would suggest an uninstall then a reinstall of v9 (back up your config first).
  10. tobiastromm
    Jun 26, 2010
    138
    I will try it.
    If help, I upload the system log to http://www.4shared.com/file/GdVNL85b/LogFiles.html
    Tha password to open the file is 3cx@123
    Thank You.
  11. tobiastromm
    Jun 26, 2010
    138
    I do this:
    http://support.microsoft.com/kb/922918/en-us
    The service start.
    I will test tomorrow again (when restart the server) and post the result.
    Thank You.
  12. abc123
    Nov 9, 2009
    712
    Glad it started.
    I think that it is a symptom of another problem though.
    I dont know if these would rely on windows trace services which is the cause of those other errors.
    Possibly a corruption or not enough resources on your server to run everything? What are your CPU and Memory %'s?
  13. tobiastromm
    Jun 26, 2010
    138
    Ei
    so I think the problem is the hardware too old.
    I did change the value to 9000.
    The service started correctly in the morning when the server did start.
    Thank You.
      File size:
      30 KB
      1,199
  14. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,406
    81
    Old hardware dhouldn't be a problem :p
    Besides we have people running on 1GhZ cpus and 256mb of ram.
    What did you do exactly to fix this?
  15. tobiastromm
    Jun 26, 2010
    138
    Leonidas,
    I did add the registry DWORD Value like Microsoft KB say.
    But i did need to change to 90000 (Microsoft say to change to 60000):
    I think it´s because this computer has a lot of services.
    Thank You.
  16. abc123
    Nov 9, 2009
    712
    I would stop and then manually start the services and look at the load and also which service dependents take the time to restart. It could be a bad installation or it could be just slow reading from the disk.
