3cx Phonesystem v14SP2 why removing feature on call recordings?
Discussion in 'Ideas' started by mic.max, Jan 28, 2016.
  1. mic.max
    Nov 24, 2010
    56
    why removing feature on call recordings management search bar from standard version? Is incomprensible because you have blocked search functions on call management recording, is a policy to force users to upgrade to the pro version to buy?
