3cx ports
Discussion in '3CX Phone System - General' started by stash, Jun 5, 2012.
  1. stash
    stash New Member
    Feb 23, 2012
    213
    I want to ask if i need to open the 5000 5060 if i will just use local calling and im just using a FXO gateway? if yes can i know why?
    and if i will be using external what are the exact ports to be open and being port forwarded?
    Thanks,
    STASH
  2. tom_ch
    Jul 6, 2011
    69
    5000 is for MyPhone and web-based management
    5060 is for SIP-Traffic
    In this case, you don't have to open the VoIP relevant ports on your firewall because you're not dealing with a Voip-Provider.
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,530
    298
    If you are going to use a VOIP Provider 5060 UDP and TCP as well as 9000-9xxx UDP (Number of calls x 2 -> so 9000-9049 supports 25 calls).
  4. stash
    stash New Member
    Feb 23, 2012
    213
    OK got it.
    Thanks,
    STASH
