Solved 3CX Pro / Debian / own domain SSL cert expired
Discussion in '3CX Phone System - General' started by jwr17, Feb 8, 2018.
  1. jwr17
    Mar 17, 2008
    9
    We've a licensed 3CX Pro running on our own server and with own domainname and SSL certificate.
    However, the certificate expired and I see no way to access Debain (SSH as root doesn't allow connection).
    How do I install the new key and crt files on this server? I do have them in hand but can't simply copy/upload them as there is no terminal access at all.
    Thanks for some advice here
    Jan
  2. Janwillem Ronken
    Jan 2, 2018
    solved.... my root password was from an old server.
    with the right one I could access over SSH, install cert and key and all up and running
    -feeling stupid--
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    Glad to see the issue has been resolved and thank you for updating the thread
