3CX proxy manager cannot initialise
Discussion in '3CX Phone System - General' started by vcddne, Jul 31, 2011.
  1. vcddne
    Jul 31, 2011
    Hi All,
    I was trying to install the 3CX proxy manager on a windows XP pro machine.
    However, the application, upon installation, couldn't start with the following message:
    'The application failed to initialize properly (0cx0000135). Click on OK to terminate the application.'
    I thought was due to Abyss Web Server as I didn't have it installed initially. However, even after having Abyss Web Server installed, I still couldn't get it to start.
    Can anyone advise please?
    Thanks,
    Vincent
