3CX pull client name if matches phone number
Discussion in '3CX Phone System - General' started by cyberhostpro, Jul 18, 2013.
  1. cyberhostpro
    May 6, 2012
    12
    HI
    We use 3CX (v11sp4) we have Snom 360 phones and also use 3cx MyPhone on the desktop (mostly for copying and pasting phone numbers from websites and hitting call). I was wondering, we use whmcs.com billing software for all our clients. Is it possible somehow that when a call comes in, 3CX could send the phone number to query WHMCS, and if it matches a customer, the customers phone number will show on the MyPhone app (or on the snom screen) ??
    10,758
    286
    I know that the 3CX phonebook will put a name against a number even replacing whatever name is sent from your provider.
    I use that quite a bit for calls from Mobiles, where the normal name display is simply "Mobile Caller". The Phonebook allows you to substitute the actual callers name.
  3. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Also by pressing f11 that will enable you to skip copying and pasting and simply dialing right from MyPhone
  4. cyberhostpro
    May 6, 2012
    12
    thanks for replies, but none of these help me :(
