3cx recording
Discussion in '3CX Phone System - General' started by Riaan, Nov 2, 2017.
Tags:
  1. Riaan
    Jul 31, 2017
    6
    Hi guys,
    Is there any way to configure 3cx to record all calls, instead of configuring call recording per extension?
    One can easily forget to tick the option when creating new extensions.
  2. AlexDBarrett
    Jan 25, 2011
    71
    9
    Opt 1. Export all your extensions to .csv then edit the file for import.
    Opt 2. Select first extension, hold ctrl, click last extension then edit selecting Record Calls.
  3. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    No, but you can select all extensions and edit recording checkbox for all of them simultaneously.
  4. Marios Neophytou
    Marios Neophytou Support Team
    Mar 1, 2016
    240
    12
    @Riaan All the above are correct plus you can click on the first extension hold the SHIFT key and then click on the last extension to multi-select
    @AlexDBarrett CTRL is to select one by one
    Thank you
