Solved 3CX Remote Clients no longer have audio
Discussion in '3CX Phone System - General' started by ITRCO, Apr 26, 2017.
  1. ITRCO
    Apr 1, 2013
    19
    Remote clients using IP phones and 3CX Proxy Manager are working fine, but today we noticed that audio does not work on IPhone, Android and PC 3CX Phone clients when remote. I have uninstalled and reinstalled a new client on Android, with a new welcome email settings. I have tried the option of "PBX Delivers Audio" but that made no change. Calls connect but there is no audio either way.
    This has worked just fine in the past and I have made no changes to the 3CX settings or my network settings. I have kept up with updates; could something have changed?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,977
    183
    firewall test passes ok?
  3. ITRCO
    Apr 1, 2013
    19
    Yes; it passed today.
  4. craigreilly
    Feb 1, 2012
    2,977
    183
    what is the firewall? done a wireshark?
  5. ITRCO
    Apr 1, 2013
    19
    The machine is using a Windows Firewall and we are using a Juniper Firewall Router. I haven't tried wireshark yet.
  6. leejor
    10,368
    229
    Have you tried from just one, or multiple remote locations?
    Any errors (Codec?) showing in the 3CX Activity log? Registrations look OK?
    No changes made to hardware/firmware/network/windows update?
  7. ITRCO
    Apr 1, 2013
    19
    Yes, tried from multiple locations / ISPs (East Coast & West Coast USA). I don't see any errors in the log. Here is a recent attempt from an Android client. The callee got the call, heard nothing and hung up; I heard nothing on my end, too.
    04/26/2017 4:57:43 PM - Leg L:89.1[Extn:316] is terminated: Cause: BYE from local
    04/26/2017 4:57:43 PM - [CM503008]: Call(C:89): Call is terminated
    04/26/2017 4:57:43 PM - Leg L:89.2[Line:10000>>123456789] is terminated: Cause: BYE from B.B.B.B:5060
    04/26/2017 4:57:37 PM - Currently active calls - 1: [89]
    04/26/2017 4:57:31 PM - [CM503007]: Call(C:89): Line:10000>>123456789 has joined, contact <sip:KW7120jPnd@px1.nexvortex.com:5060>
    04/26/2017 4:57:31 PM - [CM503007]: Call(C:89): Extn:316 has joined, contact <sip:316@A.A.A.A:9057>
    04/26/2017 4:57:31 PM - L:89.2[Line:10000>>123456789] has joined to L:89.1[Extn:316]
    I regularly do Windows updates; did some last week. We likely haven't used this functionality since before that.
  8. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,443
    282
    What version PBX are you on? IS the option use the tunnel enabled under the extension settings?
  9. ITRCO
    Apr 1, 2013
    19
    Version is Standard 15.0.62928.5
    Block Remote Tunnel Connections is NOT checked on the extension options.
  10. YiannisH_3CX
    May 10, 2016
    4,443
    282
    Sorry i was not more clear, i meant the option that is located under extension settings / phone provisioning / choose 3CX client from the drop down list. There is an option called "Use 3CX Tunnel for remote connections (3CX Client only)".
    Is that enabled?
  11. ITRCO
    Apr 1, 2013
    19
    I don't see any 3CX Phone options. I know they used to be there! Could this have been disabled system wide?
  12. YiannisH_3CX
    May 10, 2016
    4,443
    282
    Are you sure the options are not there? See attached screenshot
  13. ITRCO
    Apr 1, 2013
    19
    Now is see it! "Use 3CX Tunnel for remote connections (3CX Client only)" was not checked. That fixed it--thank you!
  14. YiannisH_3CX
    May 10, 2016
    4,443
    282
    Glad to hear this worked for you :)
  15. ITRCO
    Apr 1, 2013
    19
    Another client continued to have this issue after updating the tunnel setting. Uninstalling and reinstalling the app on IPhone, along with a new Welcome Email did the trick.
