3cx remote.
Discussion in '3CX Phone System - General' started by naseer15nov, Jan 8, 2013.
  1. naseer15nov
    Apr 5, 2012
    HI all,
    I am using 3cx with cisco gateway. It is working fine.
    And i can connect my android & Iphone from outside.
    Now, I m Epygi IPPBX for other line.
    for both extention in same sip IP PHONE. Its also working.
    But now I can not connect my andriod from outside.
    I am using same port for both 3cx & epygi i.e 5060.
    Should I change for epygi, if yes then which port?
    Kindly reply if you have experince like that.
    Thanks.
  2. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Your post is very unclear. Perhaps Epygi's tech support can assist you.
