3CX Restore
Discussion in '3CX Phone System - General' started by dwasniak, Apr 10, 2012.
  1. dwasniak
    Apr 10, 2012
    I have a crashed system and cannot get to the backup zip files. It is a 64bit system. I have another system setup and 3cx loaded. Can I just copy the folders to the new system and if so which files or folders need to be copied?
    10,362
    226
    I'm not certain that that will work.
    If you have access to the existing disk (it didn't completely die), where were your previous backups stored, why can you not access them?
  3. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    That will not work as the database will not be populated. Always always always have the backup file copied to a different machine.
  4. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Your going to need the backup file, have you done a backup at all?
