3CX & Ringcentral
Discussion in '3CX Phone System - General' started by w3tmb, Jul 16, 2010.
  1. w3tmb
    Apr 8, 2010
    Is there anyway to add a ringcentral line a a voip provider into 3CX I cant seem to get it to work here is a example of their config
    SIP Domain: sip.ringcentral.com:5060
    Outbound Proxy: sip.ringcentral.com:5090
    User Name: 15705551212
    Password: 555555
    Authorization ID: 555555
    10,362
    227
    You don't specify what issues your are having in adding a trunk to them. Not registering? If you think that you've datafilled everything properly in 3Cx then post a 3CX log showing a failed registration. That may give a clue as to what is incorrect or missing.
  3. w3tmb
    Apr 8, 2010
    16:27:35.897 [CM504007]: Next attempt to register 10008@RC is scheduled in 5 minute
    16:27:35.891 [CM504005]: Registration failed for: 10008@RC; Cause: 401 Unauthorized; from IP:208.87.41.22:5090
    16:27:35.487 [CM504003]: Sent registration request for 10008@RC
  4. carolinainnovative
    May 4, 2009
    369
    5
    Silly question - did they actually specify a separate authorization id? you used the same "mask" (ie, all 5s) for both auth id and password - possibly leading us to believe you are using the same value for authid and password in the real config as well. If they didn't specify a separate authorization id, try using your phone number.
  5. jbowlby
    Apr 6, 2012
    5
    Was there any resolution to this?
    I'm having issues getting a new ring central digital sip trunk/line.
    Information they provided:
    User Name: 1574797XXXX
    Password: 9704XXX (Same as below)
    Authorization ID: 9704XXX (Same as above)
    In 3cx:
    External number: 1574797XXXX
    Auth ID: 9704XXX
    Authen PW: 9704XXX
    I tried outgoing call, the line doesn't register and here's the error I get when dialing out.
    16:15:05.044 [CM503003]: Call(4): Call to sip:0015555555555@sip.ringcentral.com:5060 has failed; Cause: 407 Proxy Authentication Required; from IP:199.255.123.123:5090
    Here's the failed registration..
    16:49:12.510 [CM504005]: Registration failed for: 10001@RingCentral; Cause: 401 Unauthorized; from IP:199.255.123.123:5090
  6. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,962
    180
    To me it seems ring central is blocking external users. But I have never tried ringcentral.
  7. jbowlby
    Apr 6, 2012
    5
    They currently handle our call answering and we intend to keep it for the round robin calling feature to cell phones, so I was just trying to get a sip trunk from them (keep it in the same hands) But if I can get this resolved I'm going to go with a different provider for the trunks. Any recommendations?
  8. craigreilly
    Feb 1, 2012
    2,962
    180
    I the following doesn't work - ensure your firewall is set up properly for outbound traffic on ringcentral sip port (5060?)
    http://help.ringcentral.com/articles/RC_Knowledge_Article/2070?retURL=%2Fapex%2FRCSupportSearch%3Fc%3D%26p%3D38%26k%3D%26t%3D%26l%3D%26action%3DSearchAnswer%26pageid%3Dhome%26serviceFilter%3D&popup=false&Title=Settings%20for%20SIP-based%20Phones
  9. jbowlby
    Apr 6, 2012
    5
    Well, I was able to get SIP trunks from skype working ok with it so I assume it's a ring central config issue not a firewall/ports problem.
    Our firewall isn't set to block any traffic outbound.
    The default out going proxy for ring central is 5090, We had a firewall rule setup for 3cx tunnel to allow 5090 into the 3cx server but I changed the 3cx tunnel to 5091 but the Ring Central registration still didn't work.
