3CX says GXW4104 is busy after being working normally..
Discussion in '3CX Phone System - General' started by evergreen, Aug 16, 2007.
  1. evergreen
    Nov 4, 2006
    5
    Dear all,
    I'm using GXW4104 with our free edition 3CX system. Problem is,
    When i power up the GXW4104 it is registered in the 3CX and both inbound and outbound calls work just fine. BUT!!
    Atfer some rundom time when i call outside number to be router via the GXW4104 the 3CX says busy (600) on the ip-phone.
    Here some log...
    12:58:48.421 StratInOut::eek:nCancel Call from Ext.177 to 0925975310 has been terminated; reason: Busy
    12:58:48.328 CallConf::eek:nIncoming Incoming call from Ext.177 to sip:0925975310@192.168.30.57
    12:58:30.078 CallConf::Rejected Call (C:4A) is rejected: Destination is busy
    12:58:30.078 StratInOut::eek:nCancel Call from Ext.177 to 0925975310 has been terminated; reason: Busy
    It keep saying busy till i reset the GXW4104 manually...
    I need a clue to this problem please...
    Many thanks
    Hakim
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Check line status. Is it shown yellow at that time?
  3. evergreen
    Nov 4, 2006
    5
    No, it showing green as if it's normally registered on-hook (free) status.
    Thanks for your help
  4. evergreen
    Nov 4, 2006
    5
    My GXW4104 FXO Lines:
    AC Termination Impedance:320Ohm + (1050 Ohm || 230 nF))
    I wonder is that is correct in Libya...
    Thank you very much for your help
    Hakim
