3cx sbc errors has no registered RTP session
Discussion in '3CX Phone System - General' started by dangmoss, Nov 8, 2016.
  1. dangmoss
    Oct 9, 2014
    26
    ERR | 20161107-163029.289 | 3CXTunnel | TUNL | 1096 | Bridge.cpp:694 | Has no registered RTP session for local destination 192.168.20.127:11793
    ERR | 20161107-163034.289 | 3CXTunnel | TUNL | 1096 | Bridge.cpp:694 | Has no registered RTP session for local destination 192.168.20.127:11793
    ERR | 20161107-163039.291 | 3CXTunnel | TUNL | 1096 | Bridge.cpp:694 | Has no registered RTP session for local destination 192.168.20.127:11793
    ERR | 20161107-163044.297 | 3CXTunnel | TUNL | 1096 | Bridge.cpp:694 | Has no registered RTP session for local destination 192.168.20.127:11793
    What does this mean?
  2. deanril@yahoo.com
    Oct 27, 2016
    51
    I have same error and occasional initial pause in audio(5 secs) when call first starts.
  3. IT Hamster
    May 21, 2015
    43
    I get these as well, with regularity.
    Only thing I have done to fix it is:
    Turn off Windows Firewall
    Re-install SBC software and don't use encryption
    Change FQDN to Public IP in the configuration file.
    uncomment the localSipAddr
    That seems to help keep that issue from happening.
  4. deanril@yahoo.com
    Oct 27, 2016
    51
    Will try thanks!
  5. IT Hamster
    May 21, 2015
    43
    I should add that all of those tricks worked in v12 and v14 for that error. The irony being that about 10 minutes after I posted my reply- my audio cut out with this exact issue!
    I"m running v15 on linux and i'm getting pretty consistent issues with my physical phones with one-way audio or no audio.
    ERR | 20161114-143628.235 | 3CXTunnel | TUNL | 3260 | Rtp.cpp:143 | Error reading from RTP socket 508, {RS:57804}: error 10054
    ERR | 20161114-143628.251 | 3CXTunnel | TUNL | 3260 | Rtp.cpp:143 | Error reading from RTP socket 508, {RS:57804}: error 10054
    ERR | 20161114-143628.267 | 3CXTunnel | TUNL | 3260 | Rtp.cpp:143 | Error reading from RTP socket 508, {RS:57804}: error 10054
    ERR | 20161114-143628.282 | 3CXTunnel | TUNL | 3260 | Rtp.cpp:143 | Error reading from RTP socket 508, {RS:57804}: error 10054
    ERR | 20161114-143628.313 | 3CXTunnel | TUNL | 3260 | Rtp.cpp:143 | Error reading from RTP socket 508, {RS:57804}: error 10054
    ERR | 20161114-143628.329 | 3CXTunnel | TUNL | 3260 | Rtp.cpp:143 | Error reading from RTP socket 508, {RS:57804}: error 10054
    ERR | 20161114-143644.470 | 3CXTunnel | TUNL | 3416 | Bridge.cpp:694 | Has no registered RTP session for local destination 192.168.2.122:11782
    ERR | 20161114-143644.485 | 3CXTunnel | TUNL | 3416 | Bridge.cpp:694 | Has no registered RTP session for local destination 192.168.2.122:11782
    The 3CX for Windows clients that are on the same LAN work fine- but the physical phones keep getting this issue, so it is definitely something with the SBC.
  6. IT Hamster
    May 21, 2015
    43
    So I got connected with Support and they sent me an internal build of SBC v15 that resolves this problem.
    Apparently, it's a known issue on the current production build of SBC v15.
    Once I installed the build they sent me - all the RTP problems went away.
  7. deanril@yahoo.com
    Oct 27, 2016
    51
    Can you email me your version?
    Thanks!
