3CX SBC Raspberry pi 2
Discussion in '3CX Phone System - General' started by jepcainc, Aug 4, 2015.
  1. jepcainc
    Aug 4, 2015
    Is the 3CX Session Border Controller compatible with the new "Raspberry Pi 2"?
    11,095
    327
    Because the SBC on Pi runs under Raspbian Linux there should not be an issue. But at this point, I can't confirm.
  3. jepcainc
    Aug 4, 2015
    Well its install on a Raspberry pi and its working fine but when i try it on the raspberry pi 2 its not looking to work....
  4. Anonymous
    Anonymous Guest
    It works fine on my Pi2. :D
    Installed on the NOOBS image as directed in the 3CX guide.
    This is the kit I used: http://www.amazon.com/gp/product/B00WH4AEZI?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00
  5. leejor
    11,095
    327
    Are you doing a complete, new, install on the Pi 2, or are you simply copying files from the original Pi to the Pi 2, to duplicate the configuration?
