3CX SBC without tunnel option
Discussion in 'Ideas' started by tobiastromm, Feb 18, 2016.
  1. tobiastromm
    tobiastromm New Member
    Jun 26, 2010
    138
    Please add an option to just use it as a SIP PROXY (to keep the media streams local only), without tunnel.
    This should be useful for places connected by VPN. So, you can use the PBX internal IP to make the connection and just proxy media streams.
    That way there is no need to open internet port for tunnel and its more secure to travel the packets over VPN.
    I think that you should consider that idea.
    Thanks.
