3CX SBC
Discussion in '3CX Phone System - General' started by Ravilla, Jan 11, 2018.
  1. Ravilla
    Oct 4, 2017
    66
    I have 3CX Server on the cloud and about 15 ip phone in my office so do i need to connect through 3CX SBC?
  2. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    406
    40
    Hello @Ravilla
    Yes, this would be recommended as it will keep the media streams local, which reduces the amount of internet bandwidth that local calls between phones use. Check this for more info on SBC https://www.3cx.com/docs/3cx-sbc-windows/
    Ravilla likes this.
  3. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,408
    186
    Ravilla likes this.
  4. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,249
    202
    As above, another option is to setup site to site vpn, then you configure the phones as local
    Ravilla likes this.
  5. Ravilla
    Oct 4, 2017
    66
    Hi MarioM_3CX
    Thanks you for your comment.
  6. Ravilla
    Oct 4, 2017
    66
    Hi eddv123,
    Thanks for your helpful link.
  7. Ravilla
    Oct 4, 2017
    66
    Hi Saqqara,
