Re: 3CX sends internal IP in Contact: Field / No ACK Respons
Sure thing!
One thing to note - the provider has multiple addresses from which the call could originate, in this case it comes through X.Y.Z.B, whereas only one IP is set up on the trunk for outbound purposes - X.Y.Z.C.
10:18:30.546 [CM503008]: Call(11): Call is terminated
10:18:30.546 [CM503021]: Call(11): ACK is not received
10:18:11.375 [CM503007]: Call(11): Device joined: sip:
[email protected]:5060;transport=udp
10:18:11.375 [MS210002] C:11.1:Offer provided. Connection(transcoding mode): 192.168.2.60:7056(7057)
10:18:11.375 [MS210001] C:11.3:Answer received. RTP connection[unsecure]: 192.168.2.106:3000(3001)
10:18:11.375 Remote SDP is set for legC:11.3
10:18:10.906 [CM505001]: Ext.205: Device info: Device Identified: [Man: Aastra;Mod: 9133i;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, recvonly] UserAgent: [Aastra 9133i/1.4.2.3000 Brcm Callctrl/1.5.1.0 MxSF/v3.2.8.45] PBX contact: [sip:
[email protected]:5095]
10:18:10.906 [CM503002]: Call(11): Alerting sip:
10:18:10.656 [CM503025]: Call(11): Calling Ext:Ext.205@[Dev:sip:
[email protected]:5060;transport=udp]
10:18:10.656 [MS210002] C:11.3:Offer provided. Connection(transcoding mode): 192.168.2.60:7060(7061)
10:18:10.593 [CM503004]: Call(11): Route 1: Ext:Ext.205@[Dev:sip:
10:18:10.593 [CM503010]: Making route(s) to <sip:
[email protected]:5095>
10:18:10.593 [CM505003]: Provider:[Generic SIP Trunk -] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [FreeSWITCH-mod_sofia/1.0.6-svn-exported] PBX contact: [sip
10:18:10.593 Refer: from=<sip:
[email protected]:5095>;tag=c1410750; to="8551234567:6471234567"<sip:
[email protected]:5095>;tag=60737f71; RefTo=<sip:
10:18:10.375 [MS210003] C:11.2:Answer provided. Connection(transcoding mode[unsecure]):127.0.0.1:7058(7059)
10:18:10.375 [MS210000] C:11.2:Offer received. RTP connection: 127.0.0.1:40626(40627)
10:18:10.375 Remote SDP is set for legC:11.2
10:18:06.390 [MS211000] C:11.1: X.Y.Z.B:21306 is delivering DTMF using RTP payload (RFC2833). In-Band DTMF tone detection is disabled for this call segment.
10:18:05.203 Currently active calls - 1: [11]
10:17:58.468 [CM503007]: Call(11): Device joined: sip:
[email protected]:40600;rinstance=210059fd056f8681
[email protected]:5094
10:17:58.468 [MS210003] C:11.1:Answer provided. Connection(transcoding mode[unsecure]):192.168.2.60:7056(7057)
10:17:58.453 [MS210001] C:11.2:Answer received. RTP connection[unsecure]: 127.0.0.1:40626(40627)
10:17:58.453 Remote SDP is set for legC:11.2
10:17:58.453 [CM505001]: Ext.800: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX IVR;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX IVR] PBX contact: [sip:
10:17:58.453 [CM503002]: Call(11): Alerting sip:
10:17:58.312 [CM503025]: Call(11): Calling Ext:Ext.800@[Dev:sip:
[email protected]:40600;rinstance=210059fd056f8681]
10:17:58.312 [MS210002] C:11.2:Offer provided. Connection(transcoding mode): 127.0.0.1:7058(7059)
10:17:58.250 [MS210000] C:11.1:Offer received. RTP connection: X.Y.Z.B:21306(21307)
10:17:58.250 Remote SDP is set for legC:11.1
10:17:58.250 [CM503004]: Call(11): Route 1: Ext:Ext.800@[Dev:sip:
10:17:58.250 [CM503010]: Making route(s) to <sip:
10:17:58.250 [CM505003]: Provider:[Generic SIP Trunk -] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [FreeSWITCH-mod_sofia/1.0.6-svn-exported] PBX contact: [sip
10:17:58.250 [CM503001]: Call(11): Incoming call from 6471234567@(Ln.10000@Generic SIP Trunk -) to <sip:
10:17:58.234 [CM503012]: Inbound any hours rule (8551234567) for 10000 forwards to DN:800
10:17:58.234 Looking for inbound target: called=8551234567; caller=6471234567
10:17:58.234 [CM500002]: Info on incoming INVITE:
INVITE sip:
[email protected]:5095 SIP/2.0
Via: SIP/2.0/UDP X.Y.Z.B:5094;rport=5094;branch=z9hG4bK5Kc8Sp7t5QBeD
Max-Forwards: 67
Contact: <sip:
[email protected]:5094>
To: <sip:
[email protected]>;tag=UHyHy8U9DXS1r
Call-ID: 89724be5-c81f-122e-13b3-00259010ee68
CSeq: 9676875 INVITE
Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, MESSAGE, UPDATE, INFO, REGISTER, REFER, NOTIFY
Supported: timer, precondition, path, replaces
User-Agent: FreeSWITCH-mod_sofia/1.0.6-svn-exported
Allow-Events: talk, refer
Privacy: none
P-Asserted-Identity: "6471234567" <sip:
[email protected]>
Content-Length: 0
P-hint: outbound->inbound
X-PeerUuid: 3000
X-SrcIp: X.Y.Z.B
X-FS-Support: update_display
