3CX server and Patton 4552 no active line
Discussion in '3CX Phone System - General' started by erwan44, May 20, 2008.
  1. erwan44
    May 19, 2008
    hi,
    we have tryed to configure the patton 4552 with 3cx server. using the configuration fil generated by 3cx, but the line is not registered...
    if any body have a solution as a good configuration for this hardware, i am interested :) ....
    thank all
    my configuration files.
    # For SN-4552 1-port BRI
    # Author: Kevin Attard Compagno
    # Date: 2008-04-03
    # Contact: kevin@3cx.com
    webserver port 80 language en
    system
    ic voice 0
    low-bitrate-codec g729
    system
    clock-source 0 0
    profile ppp default
    profile call-progress-tone defaultDialtone
    flush-play-list
    play 1 1000 440 0
    profile call-progress-tone defaultAlertingtone
    flush-play-list
    play 1 1500 440 -7
    pause 2 3500
    profile call-progress-tone defaultBusytone
    flush-play-list
    play 1 500 440 -7
    pause 2 500
    profile call-progress-tone defaultReleasetone
    flush-play-list
    play 1 250 425 -7
    pause 2 250
    profile call-progress-tone defaultCongestiontone
    flush-play-list
    play 1 250 425 -7
    pause 2 250
    profile tone-set default
    profile voip default
    codec 1 g711alaw64k rx-length 20 tx-length 20
    codec 2 g711ulaw64k rx-length 20 tx-length 20
    fax transmission 1 relay t38-udp
    profile pstn default
    profile sip default
    no autonomous-transitioning
    profile aaa default
    method 1 local
    method 2 none
    context ip router
    interface IF_IP_WAN
    ipaddress dhcp
    tcp adjust-mss rx mtu
    tcp adjust-mss tx mtu
    interface IF_IP_LAN
    ipaddress 192.168.1.230 255.255.255.0
    context cs switch
    mapping-table calling-pi to calling-e164 MP_REM_CLIR
    map restricted to ""
    routing-table called-e164 RT_ISDN_TO_SIP_0
    route default dest-interface IF_SIP_0 MP_REM_CLIR
    interface isdn IF_ISDN_0
    route call dest-table RT_ISDN_TO_SIP_0
    interface sip IF_SIP_0
    bind gateway GW_SIP_0
    early-connect
    early-disconnect
    service default
    route call dest-interface IF_ISDN_0
    remote-party-id called-party
    address-translation outgoing-call request-uri user-part fix 10000 host-part to-header target-param none
    address-translation incoming-call called-e164 request-uri
    context cs switch
    no shutdown
    gateway sip GW_SIP_0
    call-signaling-port 5060
    bind interface IF_IP_LAN router
    service default
    domain 192.168.1.248
    defaultserver manual 192.168.1.248 loose-router
    registration-lifetime 300
    registration manual 192.168.1.248
    user 10000 authenticate name 10000 password 10000 default register
    no shutdown
    port ethernet 0 0
    medium auto
    encapsulation ip
    bind interface IF_IP_WAN router
    no shutdown
    port ethernet 0 1
    medium auto
    encapsulation ip
    no shutdown
    port bri 0 0
    clock auto
    encapsulation q921
    q921
    protocol pmp
    uni-side auto
    encapsulation q931
    q931
    protocol dss1
    uni-side user
    encapsulation cc-isdn
    bind interface IF_ISDN_0 switch
    port bri 0 0
    no shutdown
    Erwan
