Hello Ernesto,
thanks for your support. The contact saved in Bitrix has exactly the same number. I have changed the Option to exact match, but the result is still: "CRM Integration is working OK but contact number does not exist. Check log for more info or try a different number."
Log:
crm.company.list.json?filter[PHONE]=+493044351602
Response text: {"result":[],"total":0,"time":{"start":1538988121.441481,"finish":1538988121.529024,"duration":0.08754277229309082,"processing":0.013325214385986328,"date_start":"2018-10-08T10:42:01+02:00","date_finish":"2018-10-08T10:42:01+02:00"}}
Response finished
Finished scenario with empty id
Started scenario with empty id
Request text:
https://XXXXXXXXXXXXXXXXXXXXXXXX/crm.lead.list.json?filter[PHONE]=+493044351602
Response text: {"result":[],"total":0,"time":{"start":1538988121.881382,"finish":1538988121.94784,"duration":0.06645798683166504,"processing":0.00849604606628418,"date_start":"2018-10-08T10:42:01+02:00","date_finish":"2018-10-08T10:42:01+02:00"}}
Response finished
Request text:
https://XXXXXXXXXXXXcontact.list.json?filter[PHONE]=+493044351602
Response text: {"result":[],"total":0,"time":{"start":1538988122.29705,"finish":1538988122.384602,"duration":0.08755207061767578,"processing":0.013593912124633789,"date_start":"2018-10-08T10:42:02+02:00","date_finish":"2018-10-08T10:42:02+02:00"}}
Response finished
Result obtained
When I call in with enabled client side connection everything works like a charm. The website with the Bitrix contact pops up and everything works.
