3cx server updated and now my trunks are marked as unsupported
Discussion in '3CX Phone System - General' started by tastycoders, Mar 28, 2018.
  1. tastycoders
    Mar 6, 2018
    26
    I have .flowroute.com trunks they both show up with a green dot but no calls in or out.
    Not sure what to do.
    -Jason
  2. nb
    nb Support Team
    Jun 7, 2007
    2,153
    171
    make an outgoing call and make an incoming call..
    What is the error you get?
    if the trunk shows unsupported it means that you used a generic template to create the trunk. You dont need to if flowroute is supported. We have a template for Flowroute US.. Us that to create the trunks. I suggest you recreate them again.
