Hello @mrh
There are no specific addresses that will connect to the sip port of the pbx. For example your voip providers and remote stun extensions will connect to the sip port.
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
