3CX services occasionally needs to be restarted
Discussion in '3CX Phone System - General' started by denn, Sep 7, 2015.
  1. denn
    Dec 5, 2012
    15
    Every week or two I need to restart all the services in order to be able to make calls.
    I can see from the activity log that 3CX attempts to make the call, but the call never gets in.
    Code:
    07-sep-2015 08:59:34.608   Leg L:2557.1[Extn] is terminated: Cause: CANCEL from 192.168.1.217:5075
    07-sep-2015 08:59:23.145   Currently active calls - 1: [2557]
    07-sep-2015 08:59:06.951   [CM503025]: Call(C:2557): Calling T:Line:10009>>28763546@[Dev:sip:82130330@sharedtrunk.viptel.dk:5060] for L:2557.1[Extn]
    07-sep-2015 08:59:06.894   [CM503027]: Call(C:2557): From: Extn:331 ("Denni Pultz Gottfredsen" <sip:331@192.168.1.2:5060>)  to  T:Line:10009>>28763546@[Dev:sip:82130330@sharedtrunk.viptel.dk:5060]
    07-sep-2015 08:59:06.894   [CM503004]: Call(C:2557): Route 1: from L:2557.1[Extn] to T:Line:10009>>28763546@[Dev:sip:82130330@sharedtrunk.viptel.dk:5060]
    07-sep-2015 08:59:06.894   Line limit check: Current # of calls for line Lc:10009(@VIPTEL (82130330)[<sip:82130330@sharedtrunk.viptel.dk:5060>]) is 0; limit is 30
    07-sep-2015 08:59:06.894   Call(C:2557): Call from Extn:331 to 28763546 matches outbound rule '82130330'
    07-sep-2015 08:59:06.893   [CM503001]: Call(C:2557): Incoming call from Extn:331 to <sip:28763546@192.168.1.2:5060>
    07-sep-2015 08:59:06.893   NAT/ALG check:L:2557.1[Extn] REQUEST 'INVITE' - basic check passed. No information for extended checks
    Restarting the services helps, but it is really a pain. Does anyone have a clue?
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,099
    166
    What version of 3CX,
    Have you excluded 3CX folders from anti virus programs
    C:\Program Files\3CX PhoneSystem\*
    C:\ProgramData\3CX\*
  3. denn
    Dec 5, 2012
    15
    Hi Saqqare,
    V. 14 but the issue was also on v12.
    Yes I can excluded those folders.
  4. leejor
    10,754
    286
    If the hardware is the same as when you were running the previous version, then that would be my first suspect, that, or some other programme running at the same time.
    You could try stopping all other unnecessary background programmes.
    Run a memory test programme, could be bad memory causing it to hang.
    Install again, on another PC/server, apply the back-up from current system, but only use the Demo licence. Let the system run and try some test calls, over a period of time. If it doesn't require a re-start to continue functioning, then consider moving the exiting system to a new PC/server unless you can narrow down what is causing the system to stop.
