- Joined
- Feb 13, 2010
- Messages
- 3
- Reaction score
- 0
I have been thinking about routing my vonage connection through to 3CX and have been doing research on making this work and have come up with a solution which I think might work, hope you could advice whether I have understood it right (sorry if I have got the terminology wrong but I have just learnt these new words today!)
1. My vonage is currently connected to a normal handset telephone through the vonage adapter. I am thinking of connecting the end that goes into the telephone to the FXO port of Cisco SPA3102 because I called vonage and they told me that the line that comes out of the vonage adapter is of type POTS and apparently POTS connections are to be used with ports of type FX0, so I am assuming it should just work. Can anyone confirm whether this is accurate please?
2. If the above works then great, what I would like to do then is to setup around 10 to 20 extensions which when dialled should forward the call to an external number using my vonage connection, I am pretty certain this is possible when dialing an extension internally but I would like to know whether I could do the same if I dial my vonage number from my mobile. To clarify a typical example would be:
User dials into Vonage number --> Types in an extension (Possibly using digital reception?) ---> Call gets forwarded to outside number (so user who dials in gets charged for the local call only irrespective of where the call is being forwarded to) Can someone please advice whether this is all possible using 3cx?
Many Thanks in Advance for your helps!
SNV
SNV
