Solved 3cx setup with 3cx domain dont send welcome email.
Discussion in '3CX Phone System - General' started by Georgios, Apr 3, 2018.
  1. Georgios
    Apr 3, 2018
    8
    I have free license setup for the 3cx and we have problem. When we create a new extension, does not send welcome email. Since is free license as i understand we can not setup our own smtp , must be under 3cx domain. Any solution on that?
  2. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    693
    99
    Have you checked your spam folders ?
    Can you see the email hitting your email server ?
    As you are running the free version, no option to change smtp settings
  3. Georgios
    Apr 3, 2018
    8
    I know that i dont have the option to change smtp. And the problem is that never arrives in my mail server emails from 3cx smtp.
  4. Saqqara
    Mar 12, 2014
    693
    99
    Silly question, you are clicking on 'Send Welcome Email'
    You say it does not work for new extensions, what about existing extensions.
  5. Georgios
    Apr 3, 2018
    8
    For new and existing extensions the same.
  6. jimbo59
    jimbo59 Member
    Nov 17, 2017
    342
    75
    And you did a test to the default administrator?
  7. Georgios
    Apr 3, 2018
    8
    Yes i did. Just for the info, when is configured the server i received 2-4 emails for first users. But after creating new one or existing does not send (or at least not received) I monitor all incoming emails so i know this is not on any spam or blocked message.
  8. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    3,474
    239
    Hello @Georgios
    Please navigate to Settings / Email and click on the Test button. Do you get an error there or does it send the email successfully. If you get an error, what is the error you are getting?
  9. Georgios
    Apr 3, 2018
    8
    Yes, i get this error
    AuthenticationInvalidCredentials: 5.7.0 Denied
  10. Saqqara
    Mar 12, 2014
    693
    99
  11. Georgios
    Apr 3, 2018
    8
    FQDN IP is the same as i have set it up static from begining, no changes from initial setup. and FQDN resolves correctly.
  12. YiannisH_3CX
    May 10, 2016
    3,474
    239
    Try the following:
    Navigate to Settings / Network
    Set the "External IP Configuration" to "Dynamic Public IP (IP changes)"
    Restart services
    Wait a few minutes and try the email test again. If this works you can set the IP back to static if you have a static IP.
  13. Georgios
    Apr 3, 2018
    8
    Did that and seems that worked. Changed back to static IP and worked also. But now i get Login access denied. Too many incorrect login attempts. Try later or contact the Administrator.
  14. Saqqara
    Mar 12, 2014
    693
    99
    You need to access your console from another wan IP address, as your one has been blacklisted.
    When you are, on the front screen in PBX Status, you will see 'Blacklisted IPs', where you can delete your external wan IP address.
    if you have not change any settings, the blacklist record is deleted after 24hrs
  15. Georgios
    Apr 3, 2018
    8
    Yes i did that and i ma in again. But it should have an option to whitelist an IP not only blacklist. :)
  16. YiannisH_3CX
    May 10, 2016
    3,474
    239
    In the IP blacklist option you can add your IP and set it ti allow like the 3CX webmeeting server are set. That will whitelist your IP.
  17. YiannisH_3CX
    May 10, 2016
    3,474
    239
    Glad to see that issue has been resolved
