3CX Setup
Discussion in '3CX Phone System - General' started by aliswaidan, Apr 20, 2015.
  1. aliswaidan
    Apr 20, 2015
    Hi All,
    i'm planning to SETUP 3CX for one of my customer, he need to install it in the Main branch and publish it through SOPHOS Firewall.
    i am trying to install this 3cx now in my lab to test it. but i'm having some problems, i am not able to pass by firewall checker process even i am not able to connect locally to the server from my android telephone.
    can anyone advise what's the full requirements to install and publish a 3cx phone system to used by ANDROID and iOS.
    thank you.
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,257
    203
    Check to see if you have the correct ports open - http://www.3cx.com/docs/firewall-router-configuration-voip/
  3. aliswaidan
    Apr 20, 2015
    Dear Saqqara,
    what about the local connectivity ????
  4. Saqqara
    Mar 12, 2014
    1,257
    203
    When you install the software, you enter an internal / local FQDN - change you ping this address, and IP address.
    On the machine you have installed the software, is the firewall switch on - if so test by switching it off
    How have you configured the mobiles, easy way is to send the welcome email to the user and import this into the 3CX application
