3cx sip alg failed
Discussion in '3CX Phone System - General' started by Doctor Rob, Mar 28, 2018.
  1. Doctor Rob
    Mar 28, 2018
    11
    Just an.. maybe someone can help with this. The more recent version of 3cx (I am on current 15.5.9348.3 version) now fails the firewall test for the SIP ALG. I have tested with 3rd party firewall checkers and they report all is AOK. This is an more recent issue with the latest version of 3cx.. Previous to updating 3cx it always passed the check for the SIP ALG. Now with the current one it does not work (phones seem to work just fine and normal.. but having the firewall test failed in red bothers me).. Is there an work around to get this fixed or is it a known issue with the firewall tester now? OH and FYI the SIP ALG tester I used I have to turn off 3cx on the system to run it and it passes without issue.. If I try and run it with 3cx running the sip alg detector program fails as 3cx is using the interface or port or something.
  2. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    947
    149
    what version of firewall ?
  3. Doctor Rob
    Mar 28, 2018
    11
    I use the USG PRO 4 from Ubiquiti Networks and I know the SIP alg is off being I can test that with other tools. Its only the 3cx system that states it fails the test. all the other tests show it passes with it being off. (I tried turning it on as well just to see)
  4. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,282
    67
    The 3CX SIP ALG check has 3 statuses:
    • Detected
    • Not Detected
    • Failed
    Which exact one does it report on your system?
    To check why the 3CX SIP ALG checker is failed, you would need to run a packet capture on the Ubiquiti firewall, and if you don't want to run an un-filtered capture, then you need to capture the traffic involving these 3 IPs:
    • The LAN IP of the 3CX Server
    • The WAN IP that 3CX exits from
    • The IP of the SIP ALG Server which is 151.80.125.98
    If you want me to check the capture I would need you to:
    1. Start capturing on the USG PRO 4 (not on the 3CX Server). Filtered or un-filtered does not matter for me.
    2. Run the Firewall Checker from the 3CX Management Console.
    3. Wait until it all finishes.
    4. Stop and save the capture
    What you are looking for are the the SIP messages that left from the LAN and check if they were in any way changed when leaving the WAN.
    If you want me to have a look at it, upload the capture to a file sharing site of your choice and PM me the download link.
  5. Doctor Rob
    Mar 28, 2018
    11
    AHH! that was the issue.. it was simply the IP that you guys use was put on the block list!.. any other IPs 3cx uses I should be aware of just to be sure they are not put on a block list with our firewall?
    THANK YOU!!
  6. NickD_3CX
    Jun 2, 2014
    1,282
    67
    What is listed in the presentation found here: https://www.3cx.com/3cxacademy/videos/basic/installing/ (slide 10).
    The after that for the Firewall Checker:
    • sip-alg-detector.3cx.com (the one I gave you)
    • All the IPs stun.3cx.com resolves to and their +1s, so:
      • 151.80.125.93-151.80.125.94
      • 151.80.125.107-151.80.125.108
      • 158.69.11.6-158.69.11.7
      • 158.69.11.8-158.69.11.9
    I can't think of anything else. :)
  7. nb
    nb Support Team
    Jun 7, 2007
    2,099
    142
    We will check - now it is up.. You can continue working.
  8. Doctor Rob
    Mar 28, 2018
    11
    Thank you again!
  9. coastlinetech
    Mar 21, 2018
    Nick, this is also happening to one of our clients all of a sudden too. They are using a Sonicwall TZ300 firewall and everything is configured correctly. The status comes back as failed for detecting SIP ALG. Everything else passes, phones still functioning normally with zero issues. I have PM'ed you the download link to my capture along with relevant IPs.
    Thanks.
