Solved 3cx SIP ALG
Discussion in '3CX Phone System - General' started by Tomas Raska, Dec 17, 2017.
  1. Tomas Raska
    Aug 18, 2017
    58
    6
    ww have Sonicwall Firewall with disabled SIP Transformations, but ALG check return "Failed"
    Sonicwall Settings:
    Where can the problem be?
  2. eddv123
    eddv123 Active Member
    Aug 15, 2017
    921
    143
    Hi Tomas,
    Have you setup as per this guide?
    https://www.3cx.com/docs/sonicwall-firewall-configuration/
    I am not familiar with Sonicwall as a brand but I do know of some where this setting is controlled by a CLI command, worth checking?
    Do you have a secondary gateway on this network per chance? Also if your 3CX server is on Windows have you turned off the in-built firewall?
  3. fonebox
    Dec 22, 2015
    9
    Hi There
    I'm having the same issue. I have one server with OVH and another with AWS (Windows Server 2012). SIP ALG and 3CX SIP server failing. All the ports on the Firewall are open!!
    Phil
  4. shopy
    Dec 17, 2017
    I am dealing with a similar issue but I am on fiber connection. Everything else is green, SIP ALG is disabled in the firewall and the SIP/RTP ports are forwarded to the 3CX properly.
    It used to be green but I had to restore the 3CX yesterday from another installation, they are both on Debian, and now it would not pass.
    The firewall shows nothing blocked during the tests.
  5. pact
    pact New Member
    Dec 16, 2009
    172
    31
    We have been seeing periodic times where the 3CX SIP ALG tester has been failing, changing no settings and waiting 12 hours and re-running the Firewall test suddenly allows the feature to pass.
  6. Ryan Stevens
    Dec 11, 2017
    I'm also having this issue.
  7. RodSlinger
    Apr 11, 2017
    11
    I was curious and just ran the firewall test on a unit that has always passed. No changes made. Failed.....
  8. Mark@EvoIT
    Mar 16, 2017
    19
    Having the same issue on all of my Google Cloud hosted 3CX PBX's. All fine before, noted the newly deployed one (via pbxexpress) showed failed on detecting SIP ALG when testing. Went to another one of my 3CX PB's hosted in Google Cloud and ran it only to find it failing too on that one (never has before).
    I assume something on 3CX end?
  9. pact
    pact New Member
    Dec 16, 2009
    172
    31
    Must be, lucky we have that useful service dashboard showing us all the 3CX services and their current status!
  10. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,473
    284
    Hi all,
    Can you please try again now and let us know of the results? It seems there was an issue on our side but should now be resolved. Thank you for reporting.
  11. fonebox
    Dec 22, 2015
    9
    Hi YiannisH
    I can confirm the issue is now resolved.
    testing 3CX SIP Server... done
    • stopping service... done
    • detecting SIP ALG... not detected
    • testing port 5060... done
    • starting service... done
    Phil
  12. shopy
    Dec 17, 2017
    Hi Yiannis,
    It is resolved for me as well.
    Thank you.
