3CX SIP help
Discussion in '3CX Phone System - General' started by Labowski, Sep 29, 2017.
  1. Labowski
    Sep 29, 2017
    Hi there thank you for looking, I have just started using 3CX, is it possible to use an unsupported SIP Trunk provider in 3CX? I currently use a hostcomm SIP trunk and have been very happy with their service. I would like to continue using them for the time being. I have looked for a document but haven't found out how to do it.
    Thank you
    11,095
    327
  3. us1
    us1
    Oct 19, 2015
    80
    21
    For testing purposes, using a generic SIP trunk should be OK. However, once you go into production and DEPEND on the system, I cannot emphasize how important it is to have supported SIP trunks, supported handsets, supported templates, etc. Using the vendors vetted by 3cx will make obtaining support much faster and easier as well as likely reduce the number of problems you have in the first place.
    Best of luck on your adventure!
    YiannisH_3CX likes this.
  4. Labowski
    Sep 29, 2017
    Hi there, thankyou for the help but there is no Generic option only a small list of SIP providers as follows:
    Gamma
    BT Global Services
    IT Communications Ltd
    Spitfire
    T4
    TALKTALK
    Voicefkex
    Zen
    I am using the 3cx online, hosted trial
  5. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    Yes, that also can confuse users. Maybe you can select Generic country? I think that it would be better that Generic shows when any country is selected...There is also no need for Worldwide country - just add worldwide checkbox to include it on country specific list? Menu is also wide enough to show full country name? Or they should add 3 radio buttons to select Generic, Worldwide or country specific trunk?
    #5 Sopock, Oct 6, 2017
  6. Labowski
    Sep 29, 2017
    OK cool, thankyou I can see it now that I have chosen Generic Country!
