3CX SIP PAging to smartphone
Discussion in '3CX Phone System - General' started by davidlee, Nov 19, 2016.
  1. davidlee
    Jul 7, 2016
    8
    hi , if any possible SIP paging not only to IP Phone , i want to implement PAging group to smartphone (android and IOS) for those people not inside the office using apps for 3cx or any possible way thought 3rd party apps ..?
    11,113
    329
    The device has to support paging. With Push being used rather than the App remaining open all the time (to save battery life), I can't see paging working properly. There would also have to be some way to disable it when not in the office to avoid embarrassing situations where the mobile starts loudly "talking". Doesn't really sound practical, and, if you are in the office and a page through desk sets is made, it is hoped that you are in ear-shot.
    #2 leejor, Nov 19, 2016
  3. davidlee
    Jul 7, 2016
    8
    Thank LeeJor
    Pleas advise anyone know about 3cx maximum member for the paging group ?
  4. Platonik
    Dec 29, 2016
    9
    Hello, the maximum extension members for a paging group is 64. More members can be had with Multicast Paging (virtually unlimited)
  5. StefanW
    Jun 2, 2009
    1,222
    93
    and to answer one open point, paging to mobile device (3cxphone) is not possible as push will ignore this request to not cause and inconveniences on a privacy matter and on the other hand, paging is based on invites. And push on messages...
