3CX SIP Proxy and ST2030
Discussion in '3CX Phone System - General' started by mfourtillan, Oct 26, 2009.
  1. mfourtillan
    Sep 17, 2009
    5
    My 3CX SIP Proxy working fine with SNOM300.
    But I try to configure a ST2030 to work with the SIP Proxy. I have tested several configurations, but it's not working ;
    Perhaps someone that use the ST2030 with 3CX SIP Proxy could help me ?
    Here is the log on the 3CX SIP Proxy:
    .\Stack.cpp(102) : {18:23:00.735}(Trace5):Received from local SIP stack(5080):
    brief=SipReq: REGISTER clinsight tid=7920818652687532532-7466 cseq=REGISTER contact= / 1 from(wire)
    .\Bridge.cpp(274) : {18:23:00.735}(Trace5):processing SIP message (tid=7920818652687532532-7466) from SIP stack 192.168.0.1:5080
    .\Bridge.cpp(541) : {18:23:00.735}(Trace5):preprocessing local SIP request: REGISTER, tid=7920818652687532532-7466
    .\Bridge.cpp(790) : {18:23:00.735}(Trace5):Outbound tunnel (80.XXX.XXX.XXX) is selected
    .\Bridge.cpp(602) : {18:23:00.735}(Trace5):process local request: REGISTER
    .\Bridge.cpp(325) : {18:23:00.735}(Trace5):Tunnel to 80.XXX.XXX.XXX:5090 is selected for SIP message (tid=7920818652687532532-7466)
    .\Bridge.cpp(378) : {18:23:00.953}(Trace5):Got SIP msg
    brief=SipResp: 503 tid=7920818652687532532-7466 cseq=REGISTER / 1 from(tu)
    from tunnel's connection 80.XXX.XXX.XXX:5090
    .\Bridge.cpp(393) : {18:23:00.953}(Trace5):Selected SIP stack on 192.168.0.1:5080
    .\Bridge.cpp(704) : {18:23:00.953}(Trace5):process tunnel response: 503 Service Unavailable / REGISTER
    .\Stack.cpp(162) : {18:23:00.953}(Trace5):Sending to stack(5080);
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Other side of Tunnel can not resolve FQDN 'clinsight'
