3CX SIP Proxy Manager documentation
Discussion in '3CX Phone System - General' started by pdq, Jul 15, 2010.
  1. pdq
    pdq
    Dec 3, 2009
    82
    Can we standardize the documentation for using the 3CX SIP Proxy Manager at :
    http://www.3cx.com/blog/releases/sip-proxy-manager/ ?
    Specifically:
    1. Can for screenshots of the SIP Proxy Manager show the same IPs and what is up with 0.0.0.0?
    2. I see three different WAN IPs and does not follow the parts about Typical Scenario and Assumptions and the discussion below use those IP addresses.
    I am attempting to make this work with a Cisco 503G and trying to decrypt which Ip is where is a challenge. Thanks
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    The 0.0.0.0. is the network card that you are going to use as the proxy, for other phones to connect to. I have forwarded your request.
  3. pdq
    pdq
    Dec 3, 2009
    82
    Then is should show the same IP address as the proxy screen shot above it.
    0.0.0.0 is not a valid IP
