3cx Sip Proxy -> No voice
Discussion in '3CX Phone System - General' started by Spoof, Jan 23, 2010.
  1. Spoof
    Jan 23, 2010
    5
    Hello all!
    I got a problem with my 3cx central. We got a 3cx server running on our main office. We also got a second office. Now im trying to manage that when there`s nobody on the second office, the voip automaticly goes to the main office. For that i`ve installed the SIP Proxy Manager on a stand-a-lone machine. I`ve connected the phone with the Proxy manager and the proxy manager makes the tunnel to our main office. My phone is connected and can call. The only problem i have is that if you talk in the second office, you cant hear it. So the voice part isnt working. Sometimes it works, sometimes it doesnt. You guys got any clue?
    Thanks!
  2. aesteve
    aesteve New Member
    Sep 20, 2008
    136
    It seems firewall problem.
    Can You send us the logs ?
  3. Spoof
    Jan 23, 2010
    5
    I`am now not on the location. But i got a logg wich i`ve saved. In the logg one call it worked, one time it didnt.
    On the cliënt, no firewall is running. I even stopped the Firewall service from microsoft. In the modem the ports are forwarded.
    I`ve replaced the ip from our mainoffice with 000.000.000.000
    From the Sip Proxy logg:
    Code:
    .\TCPSide.cpp(155) : {17:26:16.968}(Log2):Send reliable confirmation to master. Slave UDP channel is activated
    .\Stack.cpp(102) : {17:26:40.859}(Trace5):Received from local SIP stack(5080):
      brief=SipReq:  REGISTER 192.168.1.5 tid=67dbc1c44cb48467 cseq=REGISTER contact=102@192.168.1.65:5060 / 10109 from(wire)
    .\Bridge.cpp(304) : {17:26:40.859}(Trace5):Processing SIP message (tid=67dbc1c44cb48467) from SIP stack 10.10.10.7:5080
    .\Bridge.cpp(571) : {17:26:40.859}(Trace5):Preprocessing local SIP request: REGISTER, tid=67dbc1c44cb48467
    .\Bridge.cpp(820) : {17:26:40.859}(Trace5):Outbound tunnel (000.000.000.000) is selected
    .\Bridge.cpp(632) : {17:26:40.859}(Trace5):Process local request: REGISTER
    .\Bridge.cpp(355) : {17:26:40.859}(Trace5):Tunnel to 000.000.000.000:5090 is selected for SIP message (tid=67dbc1c44cb48467)
    .\Bridge.cpp(408) : {17:26:41.140}(Trace5):Got SIP msg
        brief=SipResp: 407 tid=67dbc1c44cb48467 cseq=REGISTER / 10109 from(tu)
        from tunnel's connection 000.000.000:5090
    .\Bridge.cpp(423) : {17:26:41.140}(Trace5):Selected SIP stack on 10.10.10.7:5080
    .\Bridge.cpp(734) : {17:26:41.140}(Trace5):Process tunnel response: 407 Proxy Authentication Required / REGISTER
    .\Stack.cpp(162) : {17:26:41.140}(Trace5):Sending to stack(5080);
    .\Stack.cpp(102) : {17:26:41.171}(Trace5):Received from local SIP stack(5080):
      brief=SipReq:  REGISTER 192.168.1.5 tid=c5ba38ca1851a4c0 cseq=REGISTER contact=102@192.168.1.65:5060 / 10110 from(wire)
    .\Bridge.cpp(304) : {17:26:41.171}(Trace5):Processing SIP message (tid=c5ba38ca1851a4c0) from SIP stack 10.10.10.7:5080
    .\Bridge.cpp(571) : {17:26:41.171}(Trace5):Preprocessing local SIP request: REGISTER, tid=c5ba38ca1851a4c0
    .\Bridge.cpp(820) : {17:26:41.171}(Trace5):Outbound tunnel (000.000.000.000) is selected
    .\Bridge.cpp(632) : {17:26:41.171}(Trace5):Process local request: REGISTER
    .\Bridge.cpp(355) : {17:26:41.171}(Trace5):Tunnel to 000.000.000.000:5090 is selected for SIP message (tid=c5ba38ca1851a4c0)
    .\Bridge.cpp(408) : {17:26:41.468}(Trace5):Got SIP msg
        brief=SipResp: 200 tid=c5ba38ca1851a4c0 cseq=REGISTER contact=102@192.168.1.65:5060 / 10110 from(tu)
        from tunnel's connection ext_ip:5090
    .\Bridge.cpp(423) : {17:26:41.468}(Trace5):Selected SIP stack on 10.10.10.7:5080
    .\Bridge.cpp(734) : {17:26:41.468}(Trace5):Process tunnel response: 200 OK / REGISTER
    .\Stack.cpp(162) : {17:26:41.468}(Trace5):Sending to stack(5080);
    .\TCPSide.cpp(155) : {17:26:46.015}(Log2):Send reliable confirmation to master. Slave UDP channel is activated
  4. aesteve
    aesteve New Member
    Sep 20, 2008
    136
    What telephone model do you have ?.
    Can you send the logs of the 3CX server ?
  5. Spoof
    Jan 23, 2010
    5
    Got the grandstream GPX-2000. I will post a logg from the server side as soon as possible.
  6. aesteve
    aesteve New Member
    Sep 20, 2008
    136
    This is the proxy log. i tell you the 3CX server logs.
  7. Spoof
    Jan 23, 2010
    5
    The log from the server side:
    The error`s witch say that the other end is not connected where because the phone wasn`t attached. So thats not what im looking for.
    Code:
    14:28:58.111  [CM503008]: Call(4134): Call is terminated
    14:28:44.587  [CM503007]: Call(4134): Device joined: sip:10000@192.168.1.6:5060
    14:28:44.584  [CM503007]: Call(4134): Device joined: sip:105@10.10.10.4:5060;transport=udp;user=phone
    14:28:36.718  [CM503002]: Call(4134): Alerting sip:10000@192.168.1.6:5060
    14:28:36.282  [CM503025]: Call(4134): Calling Unknown:0634767069@(Ln.10000@patton)@[Dev:sip:10000@192.168.1.6:5060]
    14:28:36.243  [CM503004]: Call(4134): Route 1: Unknown:0634767069@(Ln.10000@patton)@[Dev:sip:10000@192.168.1.6:5060]
    14:28:36.241  [CM503010]: Making route(s) to <sip:0634767069@192.168.1.5;user=phone>
    14:28:36.239  [CM505001]: Ext.105: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.2.1.4] PBX contact: [sip:105@192.168.1.5:5060;transport=udp]
    14:28:36.237  [CM503001]: Call(4134): Incoming call from Ext.105 to <sip:0634767069@192.168.1.5;user=phone>
    14:28:25.294  [CM503008]: Call(4133): Call is terminated
    14:28:08.064  [CM503002]: Call(4133): Alerting sip:10000@192.168.1.6:5060
    14:28:07.656  [CM503025]: Call(4133): Calling Unknown:0634767069@(Ln.10000@patton)@[Dev:sip:10000@192.168.1.6:5060]
    14:28:07.602  [CM503004]: Call(4133): Route 1: Unknown:0634767069@(Ln.10000@patton)@[Dev:sip:10000@192.168.1.6:5060]
    14:28:07.601  [CM503010]: Making route(s) to <sip:0634767069@192.168.1.5;user=phone>
    14:28:07.598  [CM505001]: Ext.105: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.2.1.4] PBX contact: [sip:105@192.168.1.5:5060;transport=udp]
    14:28:07.596  [CM503001]: Call(4133): Incoming call from Ext.105 to <sip:0634767069@192.168.1.5;user=phone>
    14:28:05.043  [CM503008]: Call(4132): Call is terminated
    14:27:49.269  [CM503007]: Call(4132): Device joined: sip:10000@192.168.1.6:5060
    14:27:49.267  [CM503007]: Call(4132): Device joined: sip:105@10.10.10.4:5060;transport=udp;user=phone
    14:27:39.520  [CM503002]: Call(4132): Alerting sip:10000@192.168.1.6:5060
    14:27:39.126  [CM503025]: Call(4132): Calling Unknown:0634767069@(Ln.10000@patton)@[Dev:sip:10000@192.168.1.6:5060]
    14:27:39.088  [CM503004]: Call(4132): Route 1: Unknown:0634767069@(Ln.10000@patton)@[Dev:sip:10000@192.168.1.6:5060]
    14:27:39.087  [CM503010]: Making route(s) to <sip:0634767069@192.168.1.5;user=phone>
    14:27:39.085  [CM505001]: Ext.105: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.2.1.4] PBX contact: [sip:105@192.168.1.5:5060;transport=udp]
    14:27:39.082  [CM503001]: Call(4132): Incoming call from Ext.105 to <sip:0634767069@192.168.1.5;user=phone>
    14:27:15.399  [CM504001]: Ext.105: new contact is registered. Contact(s): [sip:105@10.10.10.4:5060;transport=udp;user=phone/105]
    14:21:55.289  [MS105000] C:4131.1: No RTP packets were received:remoteAddr=192.168.1.5:50666,extAddr=0.0.0.0:0,localAddr=192.168.1.5:7278
    14:21:54.515  [CM503008]: Call(4131): Call is terminated
    14:21:51.049  [CM503007]: Call(4131): Device joined: sip:EndCall@127.0.0.1:40600;rinstance=0b88799b1b417092
    14:21:51.047  [CM503007]: Call(4131): Device joined: sip:150@192.168.1.5:55697;line=ojn9itpa
    14:21:51.043  [CM503002]: Call(4131): Alerting sip:EndCall@127.0.0.1:40600;rinstance=0b88799b1b417092
    14:21:50.920  [CM503025]: Call(4131): Calling Unknown:Ext.EndCall@[Dev:sip:EndCall@127.0.0.1:40600;rinstance=0b88799b1b417092]
    14:21:50.842  [CM503016]: Call(4131): Attempt to reach <sip:102@192.168.1.5;user=phone> failed. Reason: Server Failure
    14:21:50.839  [CM503003]: Call(4131): Call to sip:102@192.168.1.5 has failed; Cause: 503 Remote end of tunnel is not connected; warning: Remote end of the bridge is not connected; from IP:192.168.1.5:5080
    14:21:50.734  [CM503025]: Call(4131): Calling Ext:Ext.102@[Dev:sip:102@10.10.10.8:5060;transport=udp;user=phone]
    14:21:50.713  [CM503004]: Call(4131): Route 1: Ext:Ext.102@[Dev:sip:102@10.10.10.8:5060;transport=udp;user=phone]
    14:21:50.712  [CM503010]: Making route(s) to <sip:102@192.168.1.5;user=phone>
    14:21:50.710  [CM505001]: Ext.150: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snomSoft/5.3] PBX contact: [sip:150@192.168.1.5:5060]
    14:21:50.708  [CM503001]: Call(4131): Incoming call from Ext.150 to <sip:102@192.168.1.5;user=phone>
    14:21:48.228  [MS105000] C:4130.1: No RTP packets were received:remoteAddr=192.168.1.5:58646,extAddr=0.0.0.0:0,localAddr=192.168.1.5:7272
    14:21:47.095  [CM503008]: Call(4130): Call is terminated
    14:21:45.299  [CM503007]: Call(4130): Device joined: sip:EndCall@127.0.0.1:40600;rinstance=0b88799b1b417092
    14:21:45.297  [CM503007]: Call(4130): Device joined: sip:150@192.168.1.5:55697;line=ojn9itpa
    14:21:45.293  [CM503002]: Call(4130): Alerting sip:EndCall@127.0.0.1:40600;rinstance=0b88799b1b417092
    14:21:45.110  [CM503025]: Call(4130): Calling Unknown:Ext.EndCall@[Dev:sip:EndCall@127.0.0.1:40600;rinstance=0b88799b1b417092]
    14:21:45.089  [CM503016]: Call(4130): Attempt to reach <sip:105@192.168.1.5;user=phone> failed. Reason: Server Failure
    14:21:45.089  [CM503003]: Call(4130): Call to sip:105@192.168.1.5 has failed; Cause: 503 Remote end of tunnel is not connected; warning: Remote end of the bridge is not connected; from IP:192.168.1.5:5080
    14:21:45.036  [CM503025]: Call(4130): Calling Ext:Ext.105@[Dev:sip:105@10.10.10.4:5060;transport=udp;user=phone]
    14:21:45.000  [CM503004]: Call(4130): Route 1: Ext:Ext.105@[Dev:sip:105@10.10.10.4:5060;transport=udp;user=phone]
    14:21:44.999  [CM503010]: Making route(s) to <sip:105@192.168.1.5;user=phone>
    14:21:44.997  [CM505001]: Ext.150: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snomSoft/5.3] PBX contact: [sip:150@192.168.1.5:5060]
    14:21:44.995  [CM503001]: Call(4130): Incoming call from Ext.150 to <sip:105@192.168.1.5;user=phone>
    14:21:38.187  [MS105000] C:4129.1: No RTP packets were received:remoteAddr=192.168.1.5:63436,extAddr=0.0.0.0:0,localAddr=192.168.1.5:7266
    14:21:37.706  [CM503008]: Call(4129): Call is terminated
    14:21:30.723  [CM503007]: Call(4129): Device joined: sip:EndCall@127.0.0.1:40600;rinstance=0b88799b1b417092
    14:21:30.722  [CM503007]: Call(4129): Device joined: sip:150@192.168.1.5:55697;line=ojn9itpa
    14:21:30.717  [CM503002]: Call(4129): Alerting sip:EndCall@127.0.0.1:40600;rinstance=0b88799b1b417092
    14:21:30.529  [CM503025]: Call(4129): Calling Unknown:Ext.EndCall@[Dev:sip:EndCall@127.0.0.1:40600;rinstance=0b88799b1b417092]
    14:21:30.513  [CM503016]: Call(4129): Attempt to reach <sip:105@192.168.1.5;user=phone> failed. Reason: Server Failure
    14:21:30.513  [CM503003]: Call(4129): Call to sip:105@192.168.1.5 has failed; Cause: 503 Remote end of tunnel is not connected; warning: Remote end of the bridge is not connected; from IP:192.168.1.5:5080
    14:21:30.464  [CM503025]: Call(4129): Calling Ext:Ext.105@[Dev:sip:105@10.10.10.4:5060;transport=udp;user=phone]
    14:21:30.427  [CM503004]: Call(4129): Route 1: Ext:Ext.105@[Dev:sip:105@10.10.10.4:5060;transport=udp;user=phone]
    14:21:30.426  [CM503010]: Making route(s) to <sip:105@192.168.1.5;user=phone>
    14:21:30.423  [CM505001]: Ext.150: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snomSoft/5.3] PBX contact: [sip:150@192.168.1.5:5060]
    14:21:30.421  [CM503001]: Call(4129): Incoming call from Ext.150 to <sip:105@192.168.1.5;user=phone>
    14:20:59.488  [CM503008]: Call(4128): Call is terminated
    14:20:52.279  [CM503007]: Call(4128): Device joined: sip:10000@192.168.1.6:5060
    14:20:52.277  [CM503007]: Call(4128): Device joined: sip:105@10.10.10.4:5060;transport=udp;user=phone
    14:20:46.481  [CM503002]: Call(4128): Alerting sip:10000@192.168.1.6:5060
    14:20:46.152  [CM503025]: Call(4128): Calling Unknown:0634767069@(Ln.10000@patton)@[Dev:sip:10000@192.168.1.6:5060]
    14:20:46.106  [CM503004]: Call(4128): Route 1: Unknown:0634767069@(Ln.10000@patton)@[Dev:sip:10000@192.168.1.6:5060]
    14:20:46.104  [CM503010]: Making route(s) to <sip:0634767069@192.168.1.5;user=phone>
    14:20:46.101  [CM505001]: Ext.105: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.2.1.4] PBX contact: [sip:105@192.168.1.5:5060;transport=udp]
    14:20:46.100  [CM503001]: Call(4128): Incoming call from Ext.105 to <sip:0634767069@192.168.1.5;user=phone>
    14:20:44.602  [CM503008]: Call(4127): Call is terminated
    14:20:41.581  [CM503007]: Call(4127): Device joined: sip:10000@192.168.1.6:5060
    14:20:41.579  [CM503007]: Call(4127): Device joined: sip:105@10.10.10.4:5060;transport=udp;user=phone
    14:20:33.826  [CM503002]: Call(4127): Alerting sip:10000@192.168.1.6:5060
    14:20:33.360  [CM503025]: Call(4127): Calling Unknown:0634767069@(Ln.10000@patton)@[Dev:sip:10000@192.168.1.6:5060]
    14:20:33.331  [CM503004]: Call(4127): Route 1: Unknown:0634767069@(Ln.10000@patton)@[Dev:sip:10000@192.168.1.6:5060]
    14:20:33.329  [CM503010]: Making route(s) to <sip:0634767069@192.168.1.5;user=phone>
    14:20:33.327  [CM505001]: Ext.105: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.2.1.4] PBX contact: [sip:105@192.168.1.5:5060;transport=udp]
    14:20:33.325  [CM503001]: Call(4127): Incoming call from Ext.105 to <sip:0634767069@192.168.1.5;user=phone>
    14:20:32.772  [CM503008]: Call(4126): Call is terminated
    14:17:52.546  [CM503007]: Call(4126): Device joined: sip:10000@192.168.1.6:5060
    14:17:52.543  [CM503007]: Call(4126): Device joined: sip:105@10.10.10.4:5060;transport=udp;user=phone
    14:17:44.731  [CM503002]: Call(4126): Alerting sip:10000@192.168.1.6:5060
    14:17:44.357  [CM503025]: Call(4126): Calling Unknown:0634767069@(Ln.10000@patton)@[Dev:sip:10000@192.168.1.6:5060]
    14:17:44.320  [CM503004]: Call(4126): Route 1: Unknown:0634767069@(Ln.10000@patton)@[Dev:sip:10000@192.168.1.6:5060]
    14:17:44.318  [CM503010]: Making route(s) to <sip:0634767069@192.168.1.5;user=phone>
    14:17:44.315  [CM505001]: Ext.105: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.2.1.4] PBX contact: [sip:105@192.168.1.5:5060;transport=udp]
    14:17:44.315  [CM503001]: Call(4126): Incoming call from Ext.105 to <sip:0634767069@192.168.1.5;user=phone>
    14:17:41.817  [CM503008]: Call(4125): Call is terminated
    14:17:15.926  [CM503007]: Call(4125): Device joined: sip:10000@192.168.1.6:5060
    14:17:15.924  [CM503007]: Call(4125): Device joined: sip:105@10.10.10.4:5060;transport=udp;user=phone
    14:17:06.834  [CM503002]: Call(4125): Alerting sip:10000@192.168.1.6:5060
    14:17:06.410  [CM503025]: Call(4125): Calling Unknown:0634767069@(Ln.10000@patton)@[Dev:sip:10000@192.168.1.6:5060]
    14:17:06.365  [CM503004]: Call(4125): Route 1: Unknown:0634767069@(Ln.10000@patton)@[Dev:sip:10000@192.168.1.6:5060]
    14:17:06.363  [CM503010]: Making route(s) to <sip:0634767069@192.168.1.5;user=phone>
    14:17:06.359  [CM503001]: Call(4125): Incoming call from Ext.105 to <sip:0634767069@192.168.1.5;user=phone>
    14:16:52.829  [CM503007]: Call(4124): Device joined: sip:10000@192.168.1.6:5060
    14:16:42.653  [CM503002]: Call(4124): Alerting sip:10000@192.168.1.6:5060
    14:16:42.217  [CM503004]: Call(4124): Route 1: Unknown:0634767069@(Ln.10000@patton)@[Dev:sip:10000@192.168.1.6:5060]
    14:16:42.213  [CM505001]: Ext.105: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.2.1.4] PBX contact: [sip:105@192.168.1.5:5060;transport=udp]
    14:16:41.893  [CM503008]: Call(4123): Call is terminated
    14:15:39.101  [CM503007]: Call(4123): Device joined: sip:105@10.10.10.4:5060;transport=udp;user=phone
    14:15:29.177  [CM503025]: Call(4123): Calling Unknown:0634767069@(Ln.10000@patton)@[Dev:sip:10000@192.168.1.6:5060]
    14:15:29.138  [CM503010]: Making route(s) to <sip:0634767069@192.168.1.5;user=phone>
    14:15:29.134  [CM503001]: Call(4123): Incoming call from Ext.105 to <sip:0634767069@192.168.1.5;user=phone>
    14:15:13.690  [CM503007]: Call(4122): Device joined: sip:EndCall@127.0.0.1:40600;rinstance=0b88799b1b417092
    14:15:13.685  [CM503002]: Call(4122): Alerting sip:EndCall@127.0.0.1:40600;rinstance=0b88799b1b417092
    14:15:13.481  [CM503016]: Call(4122): Attempt to reach <sip:0634767069@192.168.1.5;user=phone> failed. Reason: Server Failure
  8. aesteve
    aesteve New Member
    Sep 20, 2008
    136
    i was having the same problem and the problem was the windows firewall.
    I did solved the remote extensions with Proxy Manager. Is very easy to configure and works fine.
  9. Spoof
    Jan 23, 2010
    5
    On the sip proxy side i disabled the firewall.
    Do you mean the server side?
    I will check the ports again.
  10. StaffKB
    Jan 5, 2010
    97
    Disable the Windows firewall from the services.msc of windows and any antivirus that can block traffic from the machine running the Sip Proxy Manager.
    Regards,
