3cx sip trunking
Discussion in '3CX Phone System - General' started by forbewing, Oct 22, 2017.
  1. forbewing
    Oct 19, 2017
    hey am a newbie in 3cx and i recently installed it. i keep getting call failed, declined when ever a try to make an internal call via the extensions but devices can chat and do conferencing between each other.
    my question is does 3cx requires sip trunking to make internal calls?
  2. Rev E Miller
    Oct 22, 2017
    25
    9
    I was making calls 'in house' ext to ext without sip trunking working due to 'errors'. I'm also a newbie with this software.
  3. mixig
    mixig Active Member
    Dec 13, 2011
    519
    11
    For internal calls you dont need a sip trunk.
    Check are your extensions are registered and take a look the 3cx log, what does it says.
  4. leejor
    10,567
    246
    What type of sets are you using? As mentioned, check the 3CX Activity Log. It will show what happened to the call and why, it did not complete, if it made it to the PBX. Are the sets and the PBX, on the same LAN?
