3CX, sipgate and N95
Discussion in '3CX Phone System - General' started by _Undefined, Jul 23, 2009.
  1. _Undefined
    Jul 23, 2009
    I'm having some problems with incoming calls on 3CX. I have an N95 logged in on 100, and X-Lite on 101. If I set the sipgate line to go to X-Lite, the phone rings as it should, but if I set it to the N95, I get some weird messages in the logging, and the phone doesn't ring.
    Code:
    00:56:11.339  [CM503008]: Call(16): Call is terminated
    00:56:11.336  [CM503015]: Call(16): Attempt to reach <sip:100@10.0.0.50:5060> failed. Reason: Not Implemented
    00:56:11.335  [CM503003]: Call(16): Call to sip:100@10.0.0.50 has failed; Cause: 488 Not Acceptable Here; from IP:10.0.0.2:5060
    00:56:11.030  [CM503024]: Call(16): Calling Ext:Ext.100@[Dev:sip:100@10.0.0.2;transport=UDP]
    00:56:11.025  [CM503004]: Call(16): Route 1: Ext:Ext.100@[Dev:sip:100@10.0.0.2;transport=UDP]
    00:56:11.024  [CM503010]: Making route(s) to <sip:100@10.0.0.50:5060>
    00:56:11.022  [CM505003]: Provider:[sipgate] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:10.0.0.50:5060]
    00:56:11.019  [CM503001]: Call(16): Incoming call from anonymous@(Ln.10000@sipgate) to <sip:100@10.0.0.50:5060>
    I know what the errors mean, just not sure why it's doing it.
    The N95 is registered and can make and receive calls from/to X-Lite.
    Anyone have any ideas?
    Thanks.
    11,095
    327
    10.0.0.50 is the N95. Which device has IP 10.0.0.2?
  3. _Undefined
    Jul 23, 2009
    10.0.0.50 is the 3CX server, the N95 is on 10.0.0.2.
  4. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    It is the answer...
