This is what the logs show
21-Nov-2014 09:57:24.895 Leg L:5.1[Extn] is terminated: Cause: BYE from PBX
21-Nov-2014 09:57:24.894 [CM503020]: Call(C:5): Normal call termination. Call originator: Extn:101. Reason: No answer
21-Nov-2014 09:57:24.894 Leg L:5.2[Line:10000>>85598756999] is terminated: Cause: 408 Request Timeout/INVITE from local
21-Nov-2014 09:57:24.894 L:5.1[Extn] failed to reach Line:10000>>85598756999, reason No Answer
21-Nov-2014 09:57:24.894 Call to T:Line:10000>>85598756999@[Dev:sip:
[email protected]:5060] from L:5.1[Extn] failed, cause: Cause: 408 Request Timeout/INVITE from local
21-Nov-2014 09:57:24.894 [CM503003]: Call(C:5): Call to <sip:
[email protected]:5060> has failed; Cause: 408 Request Timeout/INVITE from local
21-Nov-2014 09:57:13.182 Currently active calls - 1: [5]
21-Nov-2014 09:56:52.754 [CM503025]: Call(C:5): Calling T:Line:10000>>85598756999@[Dev:sip:
[email protected]:5060] for L:5.1[Extn]
21-Nov-2014 09:56:52.705 [CM503027]: Call(C:5): From: Extn:101 ("sophal" <sip:
[email protected]:5060>) to T:Line:10000>>85598756999@[Dev:sip:
21-Nov-2014 09:56:52.705 [CM503004]: Call(C:5): Route 1: from L:5.1[Extn] to T:Line:10000>>85598756999@[Dev:sip:
21-Nov-2014 09:56:52.705 Line limit check: Current # of calls for line Lc:10000(@Skype[<sip:
[email protected]:5060>]) is 0; limit is 1
21-Nov-2014 09:56:52.705 Call(C:5): Call from Extn:101 to 098756999 matches outbound rule 'Rule for Skype'
21-Nov-2014 09:56:52.704 [CM503001]: Call(C:5): Incoming call from Extn:101 to <sip:
21-Nov-2014 09:13:17.102 [CM504001]: Endpoint Extn:101: new contact is registered. Contact(s): [sip:
[email protected]:63271 / 101]
