3CX Skype Gateway Setup
Discussion in '3CX Phone System - General' started by omar.t, Apr 23, 2010.
  1. omar.t
    Apr 23, 2010
    I have tried setting up the Skype gateway but when ever I try to create a skype port or do anything with the software, it gives me a message saying I don't have rights to manage 3CX gateway for skype. Any body have an idea to why it tells me that or a way to fix it.
    Regards
    Omar
  2. MichaelB
    MichaelB 3CX Team
    3CX Support
    Aug 25, 2009
    415
    19
    Hi, on what operating system did you install skype gateway.
    Also are you Administrator or have administrative rights.
    Without rights 3cx gateway for skype will not work.
  3. omar.t
    Apr 23, 2010
    Thank you for your reply.
    I'm running on Windows 7 64Bit and i'm the administrator and there is only one windows account.
    Regards
    Omar
  4. MichaelB
    MichaelB 3CX Team
    3CX Support
    Aug 25, 2009
    415
    19
    Hi Omar, I tried to replicate your issue, Windows 7 - 64 Bit ,
    Latest Skype and latest Gateway for Skype.
    This works 100%.
    Can you do the following, Go to My Computer, Right Click and Select Manage.
    Go to Local Users and Groups > Users > Administrator (right Click > Properties ) UN check Account is disabled.
    And Log in as Administrator and open Gateway for Skype and check again.
    Thanks.
  5. Pathfinder8992
    Jun 16, 2010
    Had the same problem with 64 bit Win7. Right click on the start menu link and select run as administrator.
  6. Bob Denny
    Bob Denny New Member
    Feb 21, 2009
    131
    Or set User Account Control to minimum.
