3CX / Snom - BLF function "do not disturb"
Discussion in 'Ideas' started by comteam, Aug 12, 2016.
3CX / Snom - BLF function "do not disturb" 5 5 2votes
5/5, 2 votes
  1. comteam
    Feb 16, 2016
    Extension as BLF - If the "do not disturb" is activated, the LED is red, the LED goes out after 5 seconds.
    The LED should remain on.
    The other extension should see the extension "do not disturb" has activated.
    Too bad that this function does not work.
