- Joined
- Dec 16, 2010
- Messages
- 4
- Reaction score
- 0
Evening experts, trying to get a friend in France up and running on my 3CX system using the 3cx softphone and not having much luck. His phone registers and have managed to get him to make my deskphone (polycome ip350) ring but when I answer I get nothing and when I call him it errors. I then got him to try the 3CX tunnel and ensure that 5090 is prt fwded on my side to the server which my firewall confirms to no avail. I error as soon as I try to call him.
Code:
21:03:45.533 Requests rate from IP 192.168.1.254 is too high! Blacklisted for 334 seconds
21:03:45.533 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.89:5080;branch=z9hG4bK-d8754z-380799450662085a-2---d8754z-;rport=5080;received=192.168.1.254
Via: SIP/2.0/UDP 79.83.105.140:4790;branch=z9hG4bK-d8754z-tunneltid-1---d8754z-;rport
Via: SIP/2.0/UDP 127.0.0.1:5060;branch=z9hG4bK-d8754z-380799450662085a-1---d8754z-;rport=5060
Max-Forwards: 68
Record-Route: <sip:[email protected]:5080;user=proxy;uri="79.83.105.140:4790">
Contact: <sip:[email protected]:5060;rinstance=393cffad4ef1ae0f>
To: <sip:[email protected]:5060>
Call-ID: ZWQ3NWNhOTQ0ZTIwNDRhZGI4MTZiZDUwNTE1OWNlMWI.
CSeq: 1 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
Supported: replaces
User-Agent: 3CXPhone 5.0.14900.0
Content-Length: 0
21:03:45.533 [CM302001]: Authorization system can not identify source of: SipReq: INVITE [email protected]:5060 tid=380799450662085a cseq=INVITE [email protected]:5060 / 1 from(wire)
21:03:37.189 [CM302001]: Authorization system can not identify source of: SipReq: SUBSCRIBE [email protected]:5060 tid=41238d3efa3aa12d cseq=SUBSCRIBE [email protected]:5060 / 1 from(wire)
21:03:34.533 [CM504001]: Ext.105: new contact is registered. Contact(s): [sip:[email protected]:5060;rinstance=393cffad4ef1ae0f/105]
21:03:28.564 [CM504002]: Ext.105: a contact is unregistered. Contact(s): []
21:03:04.783 [CM302001]: Authorization system can not identify source of: SipReq: SUBSCRIBE [email protected]:5060 tid=49028138cd50ea0a cseq=SUBSCRIBE [email protected]:5060 / 1 from(wire)
21:03:04.158 [CM504001]: Ext.105: new contact is registered. Contact(s): [sip:[email protected]:5060;rinstance=dfcbee447fe07ef2/105]
21:02:57.658 [CM504002]: Ext.105: a contact is unregistered. Contact(s): []
21:02:37.033 [CM302001]: Authorization system can not identify source of: SipReq: SUBSCRIBE [email protected]:5060 tid=2e336160c5370f2e cseq=SUBSCRIBE [email protected]:5060 / 1 from(wire)
21:02:35.002 [CM504001]: Ext.103: new contact is registered. Contact(s): [sip:[email protected]:5060;rinstance=e544cc4525a9a72f/103]
21:01:11.424 [CM503008]: Call(32): Call is terminated
21:01:06.611 Currently active calls - 1: [32]
21:01:05.783 [CM503007]: Call(32): Device joined: sip:[email protected]:5060
21:01:03.392 [CM505001]: Ext.100: Device info: Device Identified: [Man: Polycom;Mod: SoundPoint IP series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [PolycomSoundPointIP-SPIP_450-UA/3.3.1.0769] PBX contact: [sip:[email protected]:5060]
21:01:03.392 [CM503002]: Call(32): Alerting sip:[email protected]:5060
21:01:03.267 [CM503025]: Call(32): Calling Ext:Ext.100@[Dev:sip:[email protected]:5060]
21:01:03.221 [CM503004]: Call(32): Route 1: Ext:Ext.100@[Dev:sip:[email protected]:5060]
21:01:03.221 [CM503010]: Making route(s) to <sip:[email protected]:5060>
21:01:03.221 [CM505001]: Ext.105: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 5.0.14900.0] PBX contact: [sip:[email protected]:5060]
21:01:03.221 [CM503001]: Call(32): Incoming call from Ext.105 to <sip:[email protected]:5060>
