3CX SoftPhone - Auto Provisioning not saved
Discussion in '3CX Phone System - General' started by dataunit, Apr 25, 2013.
  1. dataunit
    Sep 30, 2010
    12
    Hi there
    I've got a problem by auto provisioning my 3cx softphone. nearly every day i got the message: No SIP profile found...
    Then i have to click on "Auto provisioning" and go to 3cx management console to assign to an extension.
    I think it could be a problem with dhcp, because there are dynamic ip addresses in our network. Could this be the problem? Is it possible to do the auto provisioning with dynamic ip addresses?
    Best regards
    Rafael
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,088
    65
    I use it on a laptop and the laptop is used in numerous locations, most using DHCP. I also have clients that use it also using DHCP and these are on desktops. I have not had any such issue.
    Have you tried manually provisioning just to see if there is a difference?
