3CX Softphone BETA with TAPI ??
Discussion in 'Windows' started by lotsu99, Jan 17, 2009.
  1. lotsu99
    Jan 1, 2008
    27
    Does the TAPI work well in this version ??
    It's not working in my system ....
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,476
    67
    This softphone does NOT integrate any 3CX-depending features (excepting its built-in tunnel). Therefore, features like presence lists or TAPI will not be available. We plan to provide in the future such as features in separate modules.
    If the TAPI feature is one you need, then you still may use the Voip Client ver 7 in desktop mode as a TAPI proxy and "BLF", since there is no conflict between it and Voip Phone.
    vali
  3. deer307
    Nov 11, 2008
    Can the 3cx client(V7) show the inbound call ID ??
    I would like to integrate incoming caller’s ID in Outlook’s contacts through TAPICALL , so I need the 3cx-client to show the inbound call ID
    any suggestion
  4. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,915
    221
    Yes, 3cx voip client v7 does this already. You can use identapop for example to pop up the inbound caller record.
  5. rico06
    rico06 New Member
    Jan 11, 2008
    143
    Can you please tell us the exact command should be use to have the outlook contact be popup ??
