3CX Softphone Configuration and Vonage
Discussion in 'Windows' started by Meletios, Mar 4, 2008.
  1. Meletios
    Mar 4, 2008
    I have Vonage VOIP service, and I would like to know how to configure the 3CX Client for Windows.
    Would anyone know how to configure the 3CX softphone Windows client to work with Vonage service?
    Thank you!
  2. darrellchapman
    Nov 26, 2007
    268
    I believe you need to have a Vonage SoftPhone Line in order to use the 3CX Client with Vonage. If I remember correctly it's an extra feature that you can add when you're logged in to the Vonage user portal. I also believe it costs an extra 4 or 5 dollars a month for it.
    Let us know.
    Darrell Chapman
  3. Meletios
    Mar 4, 2008
    Thank you Mr. Chapman. That makes sense, as I would think there needs to be some sort of registration. Vonage had put out it's on PC-to-Phone software called VonageTalk. It was released as an Alpha version, and then the company dropped support and development. Maybe I can use the registration information in that software and plug it in to 3CX. We'll see. I'll loop back here and let you know.
    Thank you again!
    Meletios
