3CX Softphone Dialing into Outside IVR Systems
Discussion in '3CX Phone System - General' started by BA7389, Dec 3, 2010.
  1. BA7389
    Nov 20, 2010
    23
    Suspect that I'll answer my own question while asking it, but....Intermittently users cannot dial the additional digits needed to access IVR system menus at various outside businesses - banks, mortgage companies, etc. Problems are most consistent on remote extensions.
    Call path for the remote users is DS-3 to Internet; Internet to remote server; server to gateway; gateway to QSIG PRI in TDM PBX; QSIG PRI to NI2 PRI in TDM PBX; NI2 PRI to CLEC Paetec. Users have tried with both local and remote settings in softphone profile.
    Ideas?
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    You can try and adjust the setting of DTMF in the VOIp phone as per screenshot and try again.
