Solved 3cx softphone keep minimized in task bar
Discussion in 'Windows' started by Basheerpt, Jul 26, 2017.
Tags:
  1. Basheerpt
    Feb 15, 2017
    50
    7
    We are using 3cx ver. 14
    The softphones are working with windows 7 and 8. While installed in windows 10, it keep staying in task bar. The taskbar preview shows the contents and extensions, however cannot work with it.
    I tried all available versions but none worked.
    Anyone faced this issue and know how to solve it? I appreciate your support.
    Thank you for your support.
  2. Basheerpt
    Feb 15, 2017
    50
    7
