3CX Softphone Rendering Issue
Discussion in 'Windows' started by a1data, Aug 6, 2012.
  1. a1data
    Dec 20, 2010
    Running into an issue with the 3CX softphone on a regular basis, sometimes it will only render the upper left-hand corner (it is always the same part). This happens at least once a day. The only solution is to shut down the phone entirely and restart it. Screenshot attached. This is occuring on a Win7 64 bit OS I have tried using version 5 and 6 softphone and both have the same rendering issue.
    11,116
    329
    I would say that it is an issue with your PC. What else is running at the same time? You might want to try shutting down, or preventing unnecessary programmes from booting, then see what happens.
    Far too many people have unneeded programmes starting up when they turn on their computers. When many install, they just start up as a matter of course.
    If you open RUN, then type msconfig, there should be a startup tab. New items are usually added to the bottom of the list. If you are not sure what something is, look it up in Google. If after a restart, you have an issue, just go back an "tick" that item again. Keep track of what you untick!
    It is possible that there is an issue with your graphics card/memory allocation.
  3. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Have you attempted to uninstall 3cx soft phone and reinstall?
  4. danmac
    Oct 1, 2012
    Hi a1data
    Did you manage to resolve this issue? I have just started using 3CX phone on a Windows 64bit machine and am experiencing the same issue as you.
    I am on ver 6.0.20943.0 - maybe this is not compatible with Windows 64 bit?
    Dan
  5. desramsay
    Oct 15, 2012
    I am having the same issue, also with Win 7 Pro 64 bit. Last week it was occasional, usually only the first time the application was loaded, on second load, it would render in full. This week, it is a solid error, will only render top left quarter as in the picture above.
    I have tried all the Windows compatibility modes individually, and also tried switching off desktop backgrounds, without solving the issue. I have also tried switching from the high performance Graphics Processing Unit (Radeon) to the standard GPU (Intel), still having the problem.
    Consequently, the application is unusable at the moment.
  6. leejor
    11,116
    329
    I'm wondering if the software has an issue with a particular video chip set?
  7. ClausP
    Jul 10, 2012
    7
    I experience the same problem and created a new thread about it before I noticed this one:
    http://www.3cx.com/forums/graphic-error-with-3cx-phone-32723.html
    Did you manage to find the solution?
