Solved 3CX Softphone Switchboard
Discussion in '3CX Phone System - General' started by Anatrok, May 8, 2017.
  1. Anatrok
    May 8, 2017
    Under the Switchboard settings there is a box "Show Presence of:" and a list of all extension groups (besides DEFAULT) regardless of which extension groups the extension is actually a member of. Is there a way to remove access from seeing presence information for extensions outside of a members group?
  2. nb
    nb Support Team
    Jun 7, 2007
    2,153
    174
    Management console > Groups > Go to the group rights tab > "Publish group information to all members"
    Uncheck this so you do not publish this to all.
  3. Anatrok
    May 8, 2017
    I'm sorry, this is actually for V14 Service Pack 3.
  4. nb
    nb Support Team
    Jun 7, 2007
    2,153
    174
    I think same concept applies.. Check.. if not, best contact support if you still have issues or update.
    The longer you wait to update (Unless you really need to stay on 14) the worse you gonna find it in the future.
    Pump up all available service packs
    Take a backup
    Uninstall and install 15.5 and restore.
  5. Anatrok
    May 8, 2017
    FOUND IT! Thanks! We are staying with V14 until VAD and Hotel are at feature parity...but once it is we'll be updating!
