3CX softphone template
Discussion in 'Ideas' started by Antoine A. Telerys, May 23, 2017.
  1. Antoine A. Telerys
    Jan 31, 2017
    17
    Hello!
    While entering hundreds of extensions at once, I figures it would be interesting to be able to change the default configuration of a softphone via a template, thus gaining some time while preparing a new pbx.
    Cheers.
  2. Dave-TTG
    May 15, 2017
    25
    8
    Hi Antoine
    Which options are you wanting to set? If you mean options that are set in the 3CX management console these can be done by bulk creating extensions using the import/export CSV function in the extensions section. If you export one of your existing extensions you'll see in the CSV that each option relates to a column in Excel. Most are configured using 0=no/off or 1=yes/on
    This is my preferred way of creating multiple extensions, as you can just use excel to auto-fill down the column to copy the settings to the other new extensions. You can also use excel RAND values to generate unique random passwords. Once you've got your csv file ready just upload it and all your extensions are ready to go.
    Dave
  3. Antoine A. Telerys
    Jan 31, 2017
    17
    Hi Dave,
    I was referring to the "default url for provisioning" selector and the codecs priority.
  4. Dave-TTG
    May 15, 2017
    25
    8
    Hi Antoine
    It doesn't look like you can set those using the CSV. There is an "InterfaceIP_0" field but that only sets the default interface for IP phones.
    You can just ctrl+click and edit multiple to set the softphone interface if that helps. The next service pack will have a "Select All" button which should prove useful
