3CX Softphone tunneling problem..
Discussion in 'Windows' started by peterbunn, Jun 3, 2009.
  1. peterbunn
    Jun 3, 2009
    20
    I try and connect to the PBX via a tunnel on a PC on the same network and everything works fine. BUT! When I try and connect to the PBX from a PC not on the same network via a tunnel, it doesn't connect. I've read the manual umpteen times and followed it by the letter in regards to port forwarding. Do I need to use the Proxy Manager or is there a way without it being used?
    Any help would be appreciated!
    -Pete
  2. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    helo,
    do you have open port 5090 ?
    do you have the last VOIP phone and the last 3cx system ?
    can you send the systelm log please. you don't have need use proxy.
  3. andy123
    Jun 11, 2009
    5
    I had same sort of problem any solutions yet.
